Hello, first time posting and was unable to find similar issue. The attached file is a simple extruded bracket component done in direct modeling. When I repeatedly measure the angle between the top plane and the XY origin plane (which should be parallel) I get different results. Sometimes is will be 0.00 and sometimes is will be 8.54 x 10 to the negative seventh. Also, the lines that define the sides of the extrusion are drawn at and measure 90.0 degrees but the angle between the planes is less or more than 90 degrees (more on one side and less on the other side) in the fourth decimal place. From prior experience I know these errors propagate throughout a design. I cannot avoid this if I am conscientiously measuring yet getting inconsistent readings. Any help is greatly appreciated!
