qt.webenginecontext:
GLImplementation: desktop
Surface Type: OpenGL
Surface Profile: CompatibilityProfile
Surface Version: 4.6
Using Default SG Backend: yes
Using Software Dynamic GL: no
Using Angle: no
Init Parameters:
* application-name Fusion360
* browser-subprocess-path C:\Users\charlie\AppData\Local\Autodesk\webdeploy\production\624b40b404e655742657beed791e582133d3b3ce\QtWebEngineProcess.exe
* create-default-gl-context
* disable-d3d11
* disable-es3-gl-context
* disable-features DnsOverHttpsUpgrade,ConsolidatedMovementXY,InstalledApp,BackgroundFetch,WebOTP,WebPayments,WebUSB,PictureInPicture
* disable-gpu-rasterization
* disable-speech-api
* enable-features NetworkServiceInProcess,TracingServiceInProcess
* enable-threaded-compositing
* ignore-gpu-blocklist
* in-process-gpu
* log-severity disabled
* no-proxy-server
* use-gl desktop
[9396:3636:0801/191924.984:ERROR:tcp_socket_win.cc(352)] bind() returned an error: Only one usage of each socket address (protocol/network address/port) is normally permitted. (0x2740)
[9396:3636:0801/191924.984:ERROR:devtools_http_handler.cc(297)] Cannot start http server for devtools.
BUG OptionAdapter UseEagleRc called before setting callbacks.EagleAPI.Version = 0.1.2
[9396:23636:0801/191926.356:ERROR:database.cc(1707)] History sqlite error 5, errno 33: database is locked, sql: COMMIT
[9396:1640:0801/191926.356:ERROR:database.cc(1707)] History sqlite error 5, errno 33: database is locked, sql: COMMIT
[9396:23636:0801/191926.357:ERROR:database.cc(1707)] History sqlite error 5, errno 33: database is locked, sql: COMMIT
BUG OptionAdapter UseEagleRc called before setting callbacks.BUG OptionAdapter UseEagleRc called before setting callbacks.QString::arg: 1 argument(s) missing in %1/scripts
BUG OptionAdapter UseEagleRc called before setting callbacks.QString::arg: 1 argument(s) missing in %1/ulps
BUG OptionAdapter UseEagleRc called before setting callbacks.QString::arg: 1 argument(s) missing in %1/design rules
BUG OptionAdapter UseEagleRc called before setting callbacks.QString::arg: 1 argument(s) missing in %1/spice
Registering module: "uiHelper"
19:19:29 Will ignore disconnects: false
19:19:29 Using ws on port 58394
19:19:29 Installing exception handlers
19:19:29 Global exception handler installed
19:19:29 Installing signal handlers
19:19:29 Installed SIGHUP
19:19:29 Installed SIGTERM
19:19:29 Installed SIGINT
19:19:29 Installed SIGBREAK
19:19:29 (node:35732) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
(Use `node --trace-deprecation ...` to show where the warning was created)
19:19:30 [socket client] connected
19:19:31 [scheduleBearerTokenRefresh]: Token expiring in 14106 seconds
20230802T021931 INFO 35732 Use SQLite database at C:\Users\charlie\AppData\Local\Autodesk\Autodesk Fusion 360\<oxygen id>\co.xQJ9PsoFRf2jBm-HynHhiQ_v5.sql
20230802T021932 INFO 35732 PIMClient created with plugins: ["PIMCorePlugin","ProductPlugin","PIMConfigurationPlugin","PIMInspectionPlugin","PIMPmiPlugin","PIMShopFloorPlugin","PIMDataExtensionPlugin","PIMPhysicalPropsPlugin","PIMBomPlugin","PIMManagePlugin"]
19:19:32 [rpcHandler]: Receiving command setProxy
19:19:32 Disabling proxy
19:19:32 [rpcHandler]: Receiving command setOnlineState
19:19:32 Received event setOnlineState, onlineState: 0
19:19:32 [rpcHandler]: Receiving command triggerMigration
qt.gui.imageio: libpng warning: iCCP: known incorrect sRGB profile
Connecting to controller server
Controller server info: QHostAddress("127.0.0.1") : 51858
host connected QHostAddress("127.0.0.1") : 51942
"19:19::32.730" MAGWorkControllerHostConnection cmd sent "auth"
"19:19::32.733" MAGWorkHostControllerConnection cmd sent "auth"
"19:19::32.736" MAGWorkControllerClientConnection cmd sent "auth"
MAGWorkControllerHostConnection cmd received "auth"
"19:19::32.740" MAGWorkControllerHostConnection cmd sent "authok"
MAGWorkHostControllerConnection cmd received "auth"
"19:19::32.743" MAGWorkHostControllerConnection cmd sent "authok"
MAGWorkHostControllerConnection cmd received "authok"
Controller connected
Sending max processes: 24
"19:19::32.749" MAGWorkHostControllerConnection cmd sent "ready"
"19:19::32.754" MAGWorkClientControllerConnection cmd sent "auth"
MAGWorkControllerHostConnection cmd received "authok"
MAGWorkControllerHostConnection cmd received "ready"
MAGWorkControllerClientConnection cmd received "auth"
"19:19::32.761" MAGWorkControllerClientConnection cmd sent "authok"
MAGWorkClientControllerConnection cmd received "auth"
"19:19::32.765" MAGWorkClientControllerConnection cmd sent "authok"
MAGWorkClientControllerConnection cmd received "authok"
MAGWorkControllerClientConnection cmd received "authok"
MAG.Default: [Idle Status] Report Idle(Idle or Not): false
None
QWidget::paintEngine: Should no longer be called
QPainter::begin: Paint device returned engine == 0, type: 1
QWidget::setMinimumSize: (MainDashboardPalette_1/QTDockWidget) Negative sizes (0,-1) are not possible
QWidget::setMinimumSize: (LearningPanelPalette_1/QTDockWidget) Negative sizes (0,-1) are not possible
19:19:35 Initialize: found existing SDK instance
19:19:35 [rpcHandler]: Receiving command featureFlagsDownloaded
19:19:35 [featureFlagsDownloaded]: Received event
19:19:35 [featureFlagsDownloaded]: Feature flags on hub REDACTED with tenant 10765880: {"ffProperties":true,"ffWrite":true,"ffConfiguration":false,"ffBrep":false,"ffEliminateMigration":true,"ffFailureMock":false,"ffTransactionSave":true,"ffCompVer":true,"ffPMI":false,"ffInspection":false,"ffShopfloor":false,"ffMeCacheCommands":false,"ffAnyCADInvPart":true,"ffLightType":false,"ffPC":false,"ffPCW":false,"ffClobberSaveClearCache":true,"ffRemoveSqlV2V3":false,"ffDiagnostics":false,"ffPPExtraction":false,"ffPPExtractionForSave":false,"ffDataValidation":false,"ffCmdsRateLimitPerMinute":"600","ffRetryRemoteVersionSnapshotLimitSec":"0"}
20230802T021935 INFO 35732 getHubInfoByTenantId 10765880 undefined
19:19:35 [rpcHandler]: Receiving command setProxy
19:19:35 Disabling proxy
19:19:35 [rpcHandler]: Receiving command setOnlineState
19:19:35 Received event setOnlineState, onlineState: 0
19:19:35 [rpcHandler]: Receiving command triggerMigration
19:19:36 [documentIdentityService]: Successfully rehydrated service.
Space Collection id: co.xQJ9PsoFRf2jBm-HynHhiQ
19:19:36 Space collection id is : co.xQJ9PsoFRf2jBm-HynHhiQ
