[REP] Fusion halted on CAM simulation in particular case
CAMXPRESS
CAMXPRESS
Dear Support Team,
I have found a problem with the CAM simulation at a specific case.
Fusion version: v2.0.10564
To reproduce the problem do the following:
- Open the attached model and run the CAM simulation on the Setup.
- Set the following parameters:
>> Run the simulation and Fusion freeze when reaching the Adaptive operation.
Some side notes:
- If you increase the tolerance or lowering the accuracy it is working.
- If you remove the 4 holes from the model the problem has gone.
- I think the triangulating algorithm has the failure at the sharp peak of the
   intersection of the hole/45deg surface when the tolerance is higher than a specific value.
Joe
ryan.bales
Autodesk Support
Autodesk Support
I cannot reproduce this with those settings. If it turn up accuracy to maximum and tolerance to absurd levels like .001 mm i can get Fusion to freeze. But those very very high settings and its likely down to graphics/compute power.
Ryan Bales
Fusion 360 Product Support
seth.madore
Ryan, are you on Mac or PC? I just tried it on PC and sure enough.....
I'll let you log the ticket 😉
Seth Madore
ryan.bales
Autodesk Support
Autodesk Support
Na man you can log it 🤣. I'm on my mac right now so yeah looks PC specific.
Ryan Bales
seth.madore
CAM-31149 for reference
Seth Madore
CAMXPRESS
Hello Seth,
Thank you for your work and your report.
Joe
