Rendering Gallery files not showing
I've been facing the same problem on my Mac. Running Latest version of Fusion 360 everything works and even says local render in process but nothing shows. Don't know if the render is actually happening or nothing at all. Before I updated fusion to the latest version, the problem was there, but if I changed from render module to model module after I have started a render and go back to Render module, the files would show up. But then too, I to keep switching between modules to see progress. Now after updating, its stuck in loading the render gallery.
Anyone, got a solution or temporary fix until fusion 360 team fixes this bug?
Regards
Ashwin Gowda
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
This is a known issue that we are chasing. It is specific to Mac.
The workarounds can be found on this thread here.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Thanks James. Will wait for this to be fixed. Thanks for the work around. Will use that for the time being.
