We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Render issues
Render issues
bulcsu.bagi
Message 1 of 8
Render issues
bulcsu.bagi
Recently I have came across some issues with F360's rendering function. In-canvas rendering works fine, but when i try a non in-canvas render (local or cloud) the the background is not renders instead its rendered in a solid color, the issue is only present in some files, and I only recently came across the problem.
I have tried a fresh instal but that did not help.
I also tried to copy and duplicate the file, and render the new copy but that didn't help either
The included image is supposed to be on "plaza" background with "ground plane" and "Flatten ground" turned on.
Im using the educational version of f360 on a 2015 Macbook air, with MacOS Big Sur
in the included picture there is a mirror plain body in the central axis of the car because i only worked on one side of the car, and i use a mirror to see both sides
Thanks for any help it's much appreciated.
Bulcsu
Replies (7)
Message 2 of 8
TrippyLighting
Could you share the design ? (export as .f3d and attach to next post)
Message 3 of 8
bulcsu.bagi
sadly the file size exceeds the 71Mb limit. And i can't find another one with the same issue right now.
Message 4 of 8
dsouzasujay
@bulcsu.bagi
You can share a public link of your Fusion 360 design with or without password
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 8
bulcsu.bagi
Here is the link for a copy of the original file which has the same issue.
https://a360.co/35gjSe7
Message 6 of 8
TrippyLighting
This looks like a bug to me. It renders fine in Canvas, but the HDRI is missing in the local render.
When I disable "flatten ground" in the Scene Settings it renders fine in the local render.
In another thread we reported missing object textures. @Steven_Gao helped there.
I've been told that there are no improvements to the render environment on a road map, but looks like there are a few things that need to be cleaned up in the render environment.
Message 7 of 8
bulcsu.bagi
In the meantime I have found a makeshift solution to the problem.
Export the  project as a .ipt than import the exported file back to F360.
be aware that although this method fixes the issues with rendering but it deletes the timeline(just imports bodies), rotates everything by 90 degrees, deletes all sketches, and simplifies all textures.
I hope my solution helps if you have similar issues.
Best
Bulcsu
Message 8 of 8
jdenuijl
As additional info. In my design, it seems to happen when I'm using the tile option in appearance.. In screen render works correctly. I've added a local render and a screenshot of the in-screen render.
