Render inconsistency
djon_3V3
Message 1 of 13
djon_3V3
Hi there,
I wondered why "render in screen" and offline render showed different result.
I did not expect that, please check the pictures.
Have a nice day.
render directly in displayrender directly in displayusing the online/offline rendererusing the online/offline renderer
Replies (12)
Message 2 of 13
jodom4
Hey djon_3V3,
Fusion uses different processes for cloud rendering and local rendering. That's why you're getting different results with the two methods.
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
Message 3 of 13
djon_3V3
hi @jodom4
Thanks for your input.
None are cloud renders. The first is a "render in the canvas", second one is a local "more real" render, but still local.
But i guess that you implied that there are two engines, and one of them is used for canvas, which is why there are discrepancies. Did i get it right?
Have a nice day.
Message 4 of 13
TrippyLighting
@jodom4 that should actually not be the case as it would render (pun intended) Fusion 360's cloud render ability somewhat useless.
It also does not match my experience either. Usually the cloud and canvas render are very close if not identical.
This looks like a bug to me!
Message 5 of 13
jodom4
Jonathan Odom
Oregon, USA
Message 6 of 13
TrippyLighting
@jodom4 yes the graininess of the 1st render means it need to "cook" longer. However, I am wondering whether the OP is referencing the completely different colors ..
Message 7 of 13
djon_3V3
yes, i am referencing the color. Looks like the solder stop mask is not seen when rendering in canvas.
Sorry i did not mention that, seemed obvious to me. I'll make sure to indicate those details next time.
Message 8 of 13
SallyYang
Is it model specific issue? If yes, would you please share this model to me? And if not, did you make any changes to the preferences of PCB or rendering related settings? Thanks!
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Message 9 of 13
djon_3V3
Hi @SallyYang
I have shared the project with you, you should have gotten an invitation.
I checked an other project and had same results. No solder mask.
Message 10 of 13
SallyYang
Hi @djon_3V3 , thanks! I've got your invitation to the project. I will take a look soon.
Sally
Sally Yang
Autodesk, Inc.
Message 11 of 13
SallyYang
Hi @djon_3V3 , I've checked your model. The "in canvas render" seems to be affected by the canvases(silkscreen), if you hide the "Canvases" node from browser and try in-canvas render again, it will show the similar result as cloud/local render. I will send this issue to development team for investigation. Thanks for reporting this issue to us!
Sally
Sally Yang
Autodesk, Inc.
Message 12 of 13
djon_3V3
Hi @SallyYang
Nice one !
I hope devs will be able to sort that easily.
Do you still need to have the project shared ?
Have a great day.
Message 13 of 13
SallyYang
Hi @djon_3V3 , just feel free to stop sharing and cleanup the file I created for testing(naming with "Sally_Testing"). I've already downloaded the 3D PCB file and attached it to our defect ticket. Thanks for all your help!
Sally
Sally Yang
Autodesk, Inc.
