Rectangular pattern removing variables
andy-hot
andy-hot
I'm using a rectangular pattern with variables for the amount of copies and the gaps, but these variables always get transformed to their value and won't update when I change the variable. You can see it in the video.
For clarification the variables' values are:
TastenanzahlX = 2
Abstand + Tastenbreite = 16 (2+14)
HughesTooling
This has been a problem in the past with several different operations, thought they were all fixed. The workaround that should work is to use the parameter manager and add the variables there.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Just tried this using Fusion Version 2.0.8749 and it works fine for me so not sure why you're having problems. Only other difference is I'm using the english version.
Mark
EDIT. @andy-hot  Can you export your design as an f3d and upload here?
Mark Hughes
andy-hot
I'm still on version 2.0.7046. Maybe that's the problem. Here is my project.
Edit: Just updated to 2.0.8809. One of the values now stays as variable the gap input still won't work properly.
andy-hot
@HughesTooling Thank you, that workaround worked. Still, it is irritating and I hope errors like this get fixed as they disturb the workflow.
