I'm a big fan of Fusion and frequently use patterns to duplicate components around my design. It seems a very dependable piece of functionality.
I've got two parallel rails spanned by a perpendicular rail. I've inserted some cast brackets to hold this perpendicular rail to the parallel rails. I planned to use a rectangular pattern to place 4 perpendicular rails with brackets along the length of the parallel rails. In the preview, the rails and brackets pattern perfectly. When I press OK, the rails remain fine, however the brackets pattern the other way.
I may have strayed into an unsupported piece of functionality but thought it worthy of mention in case it is a bug or (more likely) I'm doing something wrong. The difference to what I normally do is that the cast brackets are part of another design I've inserted into my design and then broken the link.
