Rectangular Pattern Feature "No Target Body"
imaccoll
imaccoll
I have a feature used to cut an area out of a part for a hinge. I am trying to repeat the extrude cut feature. I am getting an error of "No Target Body" but I do not see a place to select the target body in the menu. The repeated feature is being used on the same body of the original feature. Any ideas?
jhackney1972
This error normally means you are trying to cut material out of a body when there is not material there to cut.  Please attach your model for a better analysis and answer.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
imaccoll
Hi John and thanks for responding. I was able to solve the problem by changing Compute Option to Optimized instead of Adjust. There was definitely material to cut, it just somehow did not see the body under the previous settings. Please see enclosed image.
jhackney1972
Glad you found your solution.  Do not forget to mark the Forum post, that solved your question, (in this case yours) by selecting the "Accept Solution" icon. This closes the question, makes the solution available to others with similar questions and acknowledges the solution as helpful. If it did not answer your question please post any further questions you have.
