- Mute
- Permalink
- Report
Recently built a brand new computer, installed Fusion360 without issue, but after a few days the program disappeared... Ok fine, I go to re-install (Running as an Admin) , and I get a "[Errno 13] Permission denied: C:\\Users\\RyanK\\AppData\\Local\\Autodesk\\webdeploy\\meta\\uninstall.wsf" Again, Ok weird. try a full system reset; Nada. Shutdown? Nada. OK, now let me try modify the program to get access to the repair utility.... and I get a
"This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem." So far I've tried; Re-installing it, Uninstalling it, Modifying it. What other options do I have besides going to Onshape?
I have a pretty high tolerance for tech issues, but tech issues on paid products with no progress, no troubleshooting help, and no dedicated support channels?.... Much lower tolerance.... Log Files attached if someone can help me.
