Re: Mouse scrolling not zooming in/out after 2.0.8809 update
Hi @Phil.E,
Thanks for your answer. This issue is actually happening on Mac. My mouse until this update was behaving with a mouse scrolling resulting in zoom in / out, but since this update it does a scroll of the view towards up or down directions. The solutions you provided for windows or mac, none of them worked for me. And the videos shows a different behavior than the one I used to have. No matter which pan, zoom,orbit shortcuts in use, it doesn't change this behavior.  So do you confirm that middle scroll wheel should always toggle scrolling of the view and not zoom in / out ?
Phil.E
Yes scroll wheel always zooms. It sounds like you are using an add-in that causes this behavior.
Do you happen to have the add-in Native Trackpad installed? Please check Tools > Scripts and addins > Addins.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
When I wrote my initial post, I had a French UI and could not see the plugin installed ( it was a while ago, but inactivated still) so I thought it has been removed a while ago. But after I putted back the UI in english followed by a restart and still not able to see it ( Transparent Tabs and not easily selectable,I had to randomly click all around it to get a tab selected), I started to dig in another direction. I reinstalled the plug-in and turn it off in fusion but still without success. Today after trying again, I deleted the NativeTrackpad.bundle file and deactivated the plugin into fusion in the mean time: it eventually got solved, it just worked the way it should. My guess is that:  this update has activated the plug-in back and on top of it I had a slight graphic issue preventing me from seeing it installed combined to a glitch or whatever it was. To got it correctly disabled you need to delete the file and uncheck the plugin in fusion. So far it's solved, but unfortunately I cannot recreate the conditions which led me into this issue. Thank you.
