Re: Error installing Fusion 360
Message 1 of 12
I got an error at fusion 360 and it said that i should reinstal.
i manage to uninstal and deleted %temp% files, and afther restart i reinstalled fusion and still got this error ! ..
pls help
Replies (11)
Message 2 of 12
Same for me.
Message 3 of 12
julia.paganucci
Autodesk Support
Autodesk Support
Hi @Anonymous ,
I moved your post as you were getting a different error message. It looks like you do not have sufficient disk space, is there anything you can remove or delete from your computer? Does this help install Fusion 360? If not, you can also follow the directions here to try to install Fusion 360 on a drive other than C:.
@Anonymous , are you receiving the same error message "-2147286928, 'There is insufficient disk space to complete operation"? Can you please attach your diagnostic logs here so I can take a closer look.
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
Message 4 of 12
hi
so 70 GB is not sufficient for installing fusion 360???
this is what you re telling me?
and why you guys dont make it simple to instal, at the instalations to select folder like all programs?
why you have to make 100 steps to make it?
Message 5 of 12
julia.paganucci
Autodesk Support
Autodesk Support
Hi @Anonymous ,
This is what the error message from the logs and your screenshot say. Since it seems like you have ample installation space, you can try downloading the installer files directly from your Autodesk Accounts (manage.autodesk.com) page using the "Download Now" or "Browser Download" options, instead of installing using the "Install Now" option. Here is more information on download methods
Let me know if you are still receiving the same error message after!
Julia Paganucci
Message 6 of 12
frank.rosquin
Any updates on this? I have the same problem.
Message 7 of 12
julia.paganucci
Autodesk Support
Autodesk Support
Hi @frank.rosquin ,
Have you tried any of the listed solutions? Can you please post your diagnostic log files here
Julia Paganucci
Message 8 of 12
frank.rosquin
Hi Julia,
I made a post about it on the forums here, but it seems to be the same problem?
As I have said in the other thread, I have tried completely removing the install, manually and with the cleaner, I have tried with --globalinstall, and as admin. I have about 20G of free disk space.
Before that, the updates were failing, and the suggested action as an uninstall and reinstall, which is now not working ^^;
Frank
Message 9 of 12
julia.paganucci
Autodesk Support
Autodesk Support
Hi @frank.rosquin ,
Are you getting the same error when downloading from manage.autodesk.com
I am also seeing an access is denied error- are you using any proxy or firewall? Please look through How to configure proxy server and firewall for Fusion 360 as well as the Ports and Domains required by Fusion 360
You can also try starting your computer in safe mode, and installing Fusion to see if you are getting the same results.
Julia Paganucci
Message 10 of 12
frank.rosquin
It is the download from manage.autodesk.com.
No proxy, the download works great, as I can see the webdeploy folder going to 2.6G.
Message 11 of 12
julia.paganucci
Autodesk Support
Autodesk Support
Hi @frank.rosquin ,
Try the following:
  1. First, check your Task Manager (Windows) or Activity Manager (Mac) to quit any processes related to Fusion 360 (On Windows, you may find "Fusion360.exe" in the Task Manager)
  2. Restart your computer will also clear any lingering applications.  Run the installer again after quitting these processes.
  3. It is also possible that virus-scanning software is blocking Fusion 360 installation. In this case, you will need to modify the security settings or temporarily disable the virus-scanning software, and then run the installer again.
  4. You may also need to reset the Internet settings. and Clear the internet browser cache.
    • Browse to Control Panel > All Control Panel Items > Internet Option.
    • In the Advanced tab, select the Reset button to reset Internet Explorer's settings to the defaults
    • In the Security tab, select Reset All Zones to Default level
    • In the Content tab, select Clear SSL state
    • Select Apply
  5. Try a different internet connection (e.g. go to a coffee shop, switch to/from a hotspot, etc.). Using an ethernet cable has also been known to help.
If you are still unable to install Fusion please attach a new copy of your logs.
Julia Paganucci
Message 12 of 12
frank.rosquin
It seems I have to completely and utterly disable Microsoft windows10 Threat Detection for fusion to do anything.
Re-enabling it afterwards makes fusion360 once again unusable.
I must say I find this quite unacceptable, I am not willing to run my windows install without it turned on. As a commercial product, I think Fusion360 should work with Threat Detection activated.
