Re: design stuck on "document still uploading"
dfletch
Message 1 of 32
dfletch
Community Visitor
Community Visitor
I have the same problem. I executed those steps and no change to the issue.
Replies (31)
Message 21 of 32
sketchbook2
Community Visitor
Community Visitor
Hi karina.harper, I've tried all of the steps listed here, including following them on my mac laptop first (I use my PC primarily) then deactivating Fusion on it. I then follow the steps on my PC and ...... doesn't work.
I am looking forward to getting this resolved!
Message 22 of 32
alfred_ramirez
Community Visitor
Community Visitor
What worked for me was to open the file manually : File -> Open, go to it, make a small change and revert it, then save it again. Cleared up instantly for me.
Message 23 of 32
karina.harper
Autodesk Support
Autodesk Support
Hi @sketchbook2
Can you share a screenshot of your problem file? Is it in the "active documents" list? You removed this file on your PC?:
 %APPDATA%\Autodesk\Neutron Platform\Options\<User ID>\login__ActiveDocuments
You might have to do it on your mac, too - I think that would be located at:
 Users>username>Library>Application Support>Autodesk > Neutron Platform > User ID > login__ActiveDocuments
If anyone in this thread has any insight into how this occurred, that would be extremely helpful. I can repro if I max out the documents in use and use Create Component in Place, but it sounds like you all aren't doing that.
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion
What's New in Fusion | Contact Support | EDU Support | Support Board Best Practices
Message 24 of 32
sketchbook2
Community Visitor
Community Visitor
ok so I deleted the login__ActiveDocuments file on my PC, went offline and the quite Fusion.
I then logged into my Mac and deleted the entire "Filelock" and "options" folders in "Users>username>Library>Application Support>Autodesk >Neutron Platform" and then restarted Fusion...... still there.
I then set every other "editable" document to un-editable, and just like that <snaps fingers> it was gone.
 I did the whole go online, sync, quite Fusion on the mac. Logged into the PC.... Gone! 🙂
Thanks so much everybody on the thread! I recommend setting every "editable" document to un-editable.
Message 25 of 32
autodeskf360S2Y7S
Community Visitor
Community Visitor
This might help in the future.
I also had a doc in the editable docs list that was stuck uploading.
After reading this thread, I opened the file by browsing through the documents, made a change ( added a cylinder) then manually saved the change, File -> Save.
After that the file was fixed in the editable docs. list
Hope this helps.
Message 26 of 32
elirazt
Community Visitor
Community Visitor
Hi, I have the same problem and tried all the options suggested here and still stuck.
I am not connected to other computers with the user.
I deleted the original file
Tried uninstalling FUSION 360
Nothing helped.. I would be happy for help
Message 27 of 32
mitchellcord7
Community Visitor
Community Visitor
wow this actually worked for me. had this issue for months and just opened the project file manually and made a save. cleared it up! thank you! issue resolved for me on 11/7/2024
Message 28 of 32
PLAmenPRINT
Probably I have deleted the file that I have to edit because it present only in the Edit tab.
The renaming or/and the deleting the "login__ActiveDocuments" file does not work.
I think I fix it as deleting the text in the "login__ActiveDocuments" file.
Message 29 of 32
karina.harper
Autodesk Support
Autodesk Support
@PLAmenPRINT if you think you have deleted the file, you can try restoring it from the web view. If you click "open on the web", then open the folder where it was originally, then open the trash, it might be there where you can restore it, make a change/save it, make it uneditable, then trash it again.
Karina
Karina Harper
Message 30 of 32
Agiru
Observer
Observer
I have the same problem. None of these options helped me 😞
It is displayed in the program, but not in the web.
Message 31 of 32
PLAmenPRINT
Here is what worked for me step by step:
- Open fusion and make it offline (upper right corner - clock icon);
- Go to - C:\Users\"your_username"\AppData\Roaming\Autodesk\Neutron Platform\Options\DKECMX34EKHN;
- Open file "login__ActiveDocuments" with notepad, delete all the text inside and save it;
- Open Fusion and make it online again;
That worked for me two times now 🙂
P.S. I don't know if that matter but before going offline i make all the projects not editable.
Message 32 of 32
Agiru
Observer
Observer
unfortunately it doesn't work for me.
At first this file is not there, but after sync it reappears 😞
