"Sufficient data not found to switch to Offline mode"
ryan61515
ryan61515
Community Visitor
Community Visitor
I recently installed Fusion360 on my laptop, and I haven't been able to get it working even once. I repeatedly get the  "Sufficient data not found to switch to Offline mode" error, and then the "cannot enter online mode either" message before Fusion exits. I've been to all the support pages and tried nearly everything; fresh installation, disabling Windows Defender and AV software, flushing my DNS, connecting to a cellphone hotspot, nothing has worked. The error I see in the logs is "20210914T104605 W 12252 Reqest: Call failed: https://js.prd.fusionapi.autodesk.com/fusion360-runtime-config/config.json : WinHttpSendRequest: 12029: A connection with the server could not be established", and navigating to that link in the browser shows me a string of text, which I believe is what is supposed to happen. However, I don't know what else I can do to fix it.  I've seen a ton of similar forum posts, but nothing has fixed my issue yet. Attached are my log files.
Rushikesh.kadam
@ryan61515 can you try the below steps:
  1. Restart the machine.
  2. Delete the available files mentioned below and then try to login Fusion.
Windows
%APPDATA%\Autodesk\Neutron Platform\Options\NMachineSpecificOptions.xml
%APPPDATA%\autodesk\Neutron Platform\Options\<O2ID>\NGlobalOptions.xml
%TEMP%\autodesk\BrowserCache
%LOCALAPPDATA%\Autodesk\Web Services\Loginstate.xml
%LOCALAPPDATA %\Autodesk\Web Services \Autodesk Fusion 360\<Build ID>\WebServicesCache.xml
%LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\<O2ID>\NsCloudBrowserCache_myhub.dat
%LOCALAPPDATA%\Autodesk\Autodesk Fusion 360\<O2ID>\ NsCloudBrowserCache_autodesk****.dat
% LOCALAPPDATA %\Autodesk\Autodesk Fusion 360\<O2ID>\P.Login\jobs.json.lck
% LOCALAPPDATA %\Autodesk\Autodesk Fusion 360\<O2ID>\W.Login\Q
% LOCALAPPDATA %\Autodesk\Autodesk Fusion 360\<O2ID>\W.Login\UploadQueuedFileList.xml
MacOS
~Library/Application Support/Autodesk/Neutron Platform/Options/NMachineSpecificOptions.xml
~Library/Application Support/Autodesk/Neutron Platform/Options/<O2ID>/NGlobalOptions.xml
$TMPDIR/Autodesk BrowserCache
~Library/Application Support/Autodesk/Web Services/Loginstate.xml
~Library/Application Support/Autodesk/Web Services/ Autodesk Fusion 360/<Build ID>/WebServicesCache.xml
~Library/Application Support/Autodesk/Autodesk Fusion 360/<O2ID>/NsCloudBrowserCache_myhub.dat
~Library/Application Support/Autodesk/Autodesk Fusion 360/<O2ID>/NsCloudBrowserCache_autodesk****.dat
~Library/Application Support/Autodesk/Autodesk Fusion 360/<O2ID>/P.Login/jobs.json.lck
~Library/Application Support/Autodesk/Autodesk Fusion 360/<O2ID>/W.Login/Q
~Library/Application Support/Autodesk/Autodesk Fusion 360/<O2ID>/W.Login/UploadQueuedFileList.xml
Hope it helps.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
