"Slow Performace" notification cannot be dismissed
autodesk3EG5W
autodesk3EG5W
I'm using a relatively ancient GPU that is no longer getting driver updates. I'm used to getting prodded about driver updates and being behind the times with hardware in general. Clicking on "Learn More" in the submenu links to https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-update-grap...
However, as far as I can tell, there is no way to dismiss this notification, so now I'm just stuck with this permanently on screen. To be clear, Fusion runs fine for what I need, at least for now.
Is there some non-obvious setting to disable this or is this just my life now?
dsouzasujay
Hi @autodesk3EG5W ,
I acknowledge that this issue is a bug and understand that it can be quite annoying. We have internally tracked this issue under the ID FUS-202539 in our internal issue tracking system.
Rest assured, we are working on this fix with priority. Once the fix is available, I will provide an update in this thread.
Additionally, I would like to inform you that we have another form thread addressing a similar problem.
Dismiss "Slow Performance" notification - Autodesk Community
Thank you for your patience and understanding.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
autodesk3EG5W
I must've missed that thread when searching. Thanks for the quick feedback.
