"Error combining geometry" trying to extrude a sketch to cut a body
StokleyWexler
Observer Observer
StokleyWexler
Observer
Observer
Hello everyone!
This is my first time getting thrown this error code. I work natively on Macs, and I have never gotten this error code before. Now that I got my first windows laptop I keep getting these error codes. As I have mentioned in the title I am trying to extrude sketch geometry to cut a body, but it is throwing this error code. I have linked the file and picture of the problem below. I am designing a neck rest. I took a scan of my neck using lidar on my phone then imported the scan into fusion as an obj file. From there I repaired the mesh to make it whole instead of missing a lot of surfaces. then I converted that mesh body into a solid body. From there I created a block that completely enveloped the solid body. I then cut out the neck solid body out of the incapsulating box. Now I am trying to extrude the sketch to cut the solid body (box) but it's throwing me the error code. Can someone please help me out?
Thank you so so so much in advance,
Stokley
jhackney1972
Your model is composed of one very complex surface body, no solid bodies are present.
John Hackney, Retired
