"Display Color Components" only shows Wireframe
marcelTC4LJ
Message 1 of 77
marcelTC4LJ
I've selected the visual style "Shaded with Visible Edges Only". However, when I switch to "Display Color Components" my models are shown as a wireframe. It's not related to a specific file as I see this behaviour even for 3rd party step files. So it looks like I accidentaly activated an unwanted option.
Replies (76)
Message 41 of 77
GRSnyder
Just to confirm, this problem remains in the January update.
Message 42 of 77
fusiondesigner
It is now March 2024, 6 months after the initial reports, and the issue is still happening.
Message 43 of 77
trebor_madoverlord
One thing I have noticed in the last update or two is that when the problem occurs, toggling "Show Component Colors" a couple of times seems to fix it (at least, until the next time)
Message 44 of 77
ckp66253
It seemed to be working a little better until the update a week or so ago but it has come back with a vengeance since the update. I started a new post and sent a crash report in  :https://forums.autodesk.com/t5/fusion-support/it-s-back-drawing-jumps-into-wireframe-view-and-won-t-...  but have received no replies only 43 views. I participate in a Zoom room full of designers and 3D printers and some are changing to Design Spark. I don't understand how Autodesk can afford to have these products and expect anyone to pay for it.
Message 45 of 77
eric.b.leahy
Still having this issue as well, occurs on both M1 and M2 silicon.
Message 46 of 77
asbissonnette
Does anyone on Apple Silicon NOT have this issue? This just started for me today and makers it nearly impossible to get anything done in Fusion... Has there been an official word from Autodesk?
Message 47 of 77
fubbi
M2 Ultra, latest Insider version. Still happening...
Message 48 of 77
GRSnyder
@trebor_madoverlord wrote: One thing I have noticed in the last update or two is that when the problem occurs, toggling "Show Component Colors" a couple of times seems to fix it (at least, until the next time)
I was pretty chuffed to try this out, but for what it's worth, I'm afraid it didn't work for me. I've been in the degenerate state several times over the last week and always tried this, but no luck so far...
Message 49 of 77
fusiondesigner
Same here for the proposed solution, toggling "Show Component Colors" back and forth even 20 times or more doesn't do anything for me. Even saving and closing the window of that specific design, then opening that design again doesn't fix it. Once it enters that state, I have never been able to fix it without completely exiting the app and relaunching it. Then, 15-20 minutes later, it happens again.
Apple M3 Macbook Pro
Message 50 of 77
jlorencik
it's frustrating. Avery day I must restart Fusion. Many times! This is a problem only native app for Apple M chip . Autodesk has a big team, but they aren't testing a native app on Apple M chips? Where can I write this problem to be resolved finally? This error is random. Sometimes when I move body, sometimes when I make Sketch, sometimes when I make Extrude or etc...
Message 51 of 77
changkeunmoon
Community Visitor
Community Visitor
MacBook Pro m3 also has that issue.
please confirm.
Message 52 of 77
mfox2S9W46
Observer
Observer
This might sound strange but have you tried updating macOS? It worked for me. Fingers crossed.
Message 53 of 77
mfox2S9W46
Observer
Observer
Never mind. The problem came back.
Message 54 of 77
glucklich21
I'll add my name along with my team's on seeing this problem persist for months now. They are on M2 Max Studios and I am on a M3 Max MBP. Wake from sleep can cause it, extrude can cause it, holes can cause it...... I think basically anything that causes a graphic "refresh" kills component color cycling.
Message 55 of 77
GRSnyder
I've been forcing myself to work in component color mode just to collect some quantitative data. With the models I'm dealing with currently, Fusion 360 never lasts more than an hour without going into this degenerate mode.
I'm more convinced than ever that whatever causes this display issue also causes F360 to crash. Not consistently. But sometimes, and in close proximity (< 10 minutes) to the occurrence of the display issue.
F360 isn't really usable in component color mode once the display problem manifests, so I always switch back to normal display once it happens. But apparently, whatever's scrambling F360's brain has already happened by that point, as evidenced by the frequency of crashes.
Message 56 of 77
alex.frostik
Observer
Observer
Happening for me as well.
Can't use component colors. Component become transparent after change
Mac M2 chip
Message 57 of 77
ondrej.slavik
The same issue, on any Apple Silicon mac I tried, no matter on configuration. The bug is there from the official release of the native Apple Silicon app.
Message 58 of 77
adamfenn28
I'm seeing this issue as well.  Now that we have a repeatable case, I wonder if there's any attention being put on this.
Message 59 of 77
Phil.E
Thanks for posting about it, it's logged as ticket FUS-149585.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 60 of 77
clm_dasher
Thanks @Phil.E , is there a ticket status we can keep an eye on for updates?  Cheers, Carl.
