"Compute All" toggles visibility of bodies.
HarrisonClassic
HarrisonClassic
I've noticed in the latest build 2.0.10440 that when I do a Compute All it toggles visibility on some bodies.
David Harrison
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
HarrisonClassic
https://autode.sk/3B0BuWm
David Harrison
jeff_strater
@HarrisonClassic - can you share this model?  In general, I have not seen this issue, so it may be specific to this design.  Thanks.
Jeff Strater
Engineering Director
HarrisonClassic
Jeff I'll send it to you.
Have been working solidly for the last two days with current Fusion build. Lots and lots of problems.
Bodies formed early in the model using sweep, then combine (intersect) all of a sudden becoming invalid some time later with "boolean errors" - not able to correct, and of course lots of dependencies relying on it.
Created a reasonably complicated sketch, mirroring operations in the sketch caused many crashes - you will see them logged
Compute All - breaking  fillets on bodies, removing sketch planes from sketches. And giving different results when run multiple times.
Really struggling.
I'll send you a like to the model.
David
David Harrison
HarrisonClassic
Here's the model Jeff - you will see the boolean error etc.
I've wasted two days, basically cant continue.
I ended up deleting a whole bunch of work to try and get back to a state where the model was useable, but can't resolve the boolean combine error.
If it's an issue with the latest F360 release, can you go back to an earlier one.
I'll send you the model.
David Harrison
jeff_strater
I'm not sure what Combine errors you are referring to.  This topic was about body visibility.  The model you sent me via PM does not look the same as in the screencast (the long, thin bodies are not visible), and when I open that design and do Compute All, I don't see any change in the body visibility (or any Combine errors):
Jeff Strater
