Push/Pull performace issue
AlphaRay123
AlphaRay123
On "complex" (extruded objects) objects the push/pull (i hope this is the english name - i marked it on the screenshot) hangs for a while.   Here actually for about 15-20 seconds. Sometimes a minute or longer.
It does not matter you using the mouse or entry an value.
Fusion360 hangs complete as you see. The browser background became black and in the app bar appers "no respond".
The problem is to come out from this. By clicking in fusion when it's ready it hangs again for a while...
The error message says that the object can't not be repaired after removing of faces.
Using extrude tool on the same faces runs smooth and without problems.
TheCADWhisperer
AlphaRay123
I've exported the arm from this version.  These are meanwhile completly redesigned - in the newer Version it hangs only about 2 seconds.
I've loaded the exported file and recorded it so you can see how long it hangs.  After the error message fusion hangs about the same time it takes from pulling to the error message.  While this i clicked in fusion so you see fusion is not responding.
Up to the error message the hand cursor stays - with the error message the sandhour cursor appears.
CPU:   actual i5-9400F with 6 x 2.9-4.1 Ghz
RAM:  20 GB DDR4
GPU:  1050 ti @ 4GB
