Push/pull is pulling edges instead of face
joePGQJY
joePGQJY
I'm following this tutorial: https://www.youtube.com/watch?v=HXRMzJWo0-Q
When I try to push/pull the first circle it seems to be pulling the edge of the circle instead of the face itself. And it also limits the pull to 10mm. Maybe this is something that changed in the UI in the last several versions? (I'm definitely an absolute beginner.)
What do I need to do to pull the face of the circle?
davebYYPCU
Make sure the sketch circle is not selected, before you select the profile shading.
Might help....
HughesTooling
In your image above it looks like you have a section view enabled.
Mark
Mark Hughes
Owner, Hughes Tooling
joePGQJY
That was exactly the problem. Thank you!
