Protected CAM operations sometimes don't stay protected
FrodoLoggins
Advisor Advisor
FrodoLoggins
Protected my toolpaths, tried posting (Fusion crashed), restarted Fusion:
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Marco.Takx
Hi @FrodoLoggins,
Can you be more clear about this situation?
Can you reproduce this behavior?
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
schuran
I have a similar situation.  I can protect a toolpath then suppress/unsuppress freatures and it stays protected.  If I save the model, shut down Fusion 360, re-start Fusion 360 and all of the toolpaths need to be regenerated.  This only started happening after the last update.
seth.madore
@schuran is this an XREF (inserted document), and have you made any updates to the parent file? Can you share your data here?
Are you on PC or Mac?
Seth Madore
