Projected arc with radius driven by user parameter does not update position
evilc
evilc
  1. Create a user parameter "Radius", set to 10mm
  2. Create a sketch with a constrained arc and set the radius to use the parameter "Radius"
  3. Create a new sketch, project the arc
  4. Create a line which is tangent to the arc
  5. Edit the "Radius" parameter and change it to 20mm
  6. BUG: The line does not change position, and the tangent constraint turns red
(view in My Videos)
evilc
Update: User Parameter is not actually required to repro this bug.
  1. Create a sketch with a constrained arc and set the radius to 10mm
  2. Create a new sketch, project the arc
  3. Create a line which is tangent to the arc
  4. Close Sketch 2 and re-open Sketch 1
  5. Edit the radiusof the arc and change it to 20mm
  6. Close Sketch 1 and re-open sketch 2
  7. BUG: The line has not changed position, and the tangent constraint is red
(view in My Videos)
jeff_strater
Thanks for reporting that, @evilc - that is, indeed a bug.  It seems to be the tangent.  If I make that line horizontal instead, it seems to work.  I'll create a bug on this.
[edit] the bug is FUS-121425
Jeff Strater
Engineering Director
