Project won´t open after latests update
mezcalyt
mezcalyt
I was editing a project last night. This morning there was an update and now I cannot open the project and I get the following error:
"Fusion can't open Toyozumi_Drone_3 v14 which was persisted by version 2.0.19440 with your current software version 2.0.18961"
Does anyone know how I can solve this issue??
a.laasW8M6T
Hi
Version 2.0.19440 is the latest version of Fusion.
Its seems somehow you have reverted to an older version of fusion(which should be impossible)
can you try clicking on "check for updates"
and seeing if there is any updates pending?
mezcalyt
Thank you.
I checked as recommended and I get that I am up to date.
I am still not able to open the design...
RajkumarIlanchelian
@mezcalyt @In the same help menu go to support and diagnostics and go to Fusion service utility. Run the repair from here and it should take you to the new version.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
mezcalyt
Thank you very much. It worked beautifully!
