Project Avatar for Folder-Level Projects Cannot be Changed After the Project is Created
mwil3287
Observer Observer
mwil3287
Observer
Observer
After creating a new project in my Team (where I am administrator) and adding files to the it, I tried to change the project avatar to my own image.  When clicking upload after selecting my image, this error message is displayed:
"You don't have required permission to change the project profile image."
I am the owner of this project , which I will refer to as Project A for the rest of this description, and am the only member (but there are two other System Groups: 'Team Administrators' and 'All Members').
However, I can change the project avatar for my other projects.  After taking a close look at the project settings, the only difference that I could find was the project type.  My other projects are all closed projects.  They were all created on a school computer running an older version of Fusion 360.  In these closed projects, I have not had any issues changing the project avatar.  However, when I created Project A on my personal computer (running version 2.0.12392), it was created as a folder level project.  The difference in versions is my best guess for the cause of the difference in project types.  If it would be useful, I can provide the version of Fusion 360 that my school computers use at a later date (I do not have access to them right now).
Curious, I created two new projects in my Fusion Team on the web app: one closed and one folder level.  Upon their creation, I set both project avatars to the image I was trying to use earlier.  Both custom avatars were successfully created and were displayed correctly when I viewed all of my projects in my Team hub.  Then, I changed both avatars to the default project avatar (the baby blue one).  Both avatars were successfully updated.  Then, I tried changing both back to my own image.  The closed project avatar updated as expected, but the folder-level project avatar refused to change back to my custom image.  When I clicked 'upload' for the folder-level project, the same error message was displayed as before:
As a workaround, I made a new closed project (just in case I need to change the avatar again) and copied all of the files from Project A (my original folder-level project) to the new project.  I was able to successfully set the project avatar to my image.
I am fairly certain that this is an isolated issue with folder-level projects, but I did not test Open or Secret projects.
Andy.Spivey
 Hi @mwil3287 - thanks for reaching out and the details!
This is a reported issue and is slated to be resolved in the next release of Fusion Team.  I would expect that to be in the next week or two!
Andy Spivey
SQA Engineer
