Processor Requirement
In the Processor Requirement you write to use a 64 bit processor but you didn't say anything about speed?
so every processor of 64 Bit will be perfect to the software ?
masa.minohara
Hi @Anonymous,
Thank you for posting in the forum! This article contains information about the "minimum" system requirements for Fusion 360, and that does not mean every processor of 64 Bit will be perfect.
Performance depends on a lot of variables so it's difficult to answer but personally I haven't seen a critical issue caused by CPU. I found a couple of related forum threads:
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
ahreum.ryu
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for your posting! Smiley Happy
If you are using the 32bit CPU, you will be unable to install Fusion 360.
I can't say that every professor will be perfect. because it depends on your purpose.
If I create simple boxes and the model is not complex, the general CPU will be fine, However, If you utilize the Large assembly, mesh data, or rendering like more functions, you may need more than the minimum. Fusion 360 system requirement is minimum specs.
For your reference, I would like to share my desktop specification.
CPU : Intel(R) Xeon(R) CPU E5-2650 v2 2.6GHZ
Memory : 32GB
Graphic Card: Quadro K5000
However, it's not a recommendation Smiley Wink
If you have further questions, please let me know.
Many thanks,
Ahreum.
Thank's guy's
