Problems with sheet metal
Have arisen problems with sheet metal, especially when using the LOFT command.
In some cases, I cannot execute the THICKNESS command for the built surface
In other cases, conversion to sheet metal fails
Finally, if these two stages can be overcome, the Flat Pattern often fails
I hope you can give me some advice.
Thanks in advance.
Sincerely, Victor
Added files:
TheCADWhisperer
Your sides are twisted.
You must use Autodesk Inventor Professional - Lofted Flange.
Fusion 360 only supports planar faces with cylindrical or conic bends - no twisted faces.
https://www.youtube.com/playlist?list=PLp5izJt_zvN29W2cEFHAK949eImc9xFOT
