Problems after update
mariuszhetman
Message 1 of 8
mariuszhetman
After launching the program, a window appears informing you that many add-ons are missing. Then, after launching it, attempting to upload an existing document or creating a new one results in the program closing. Before the update, everything worked fine.
MacOS 12.7.6, MacBookPro Intel.
Replies (7)
Message 2 of 8
rosie_lucas1
Hi @mariuszhetman,
I just wanted to follow up and see if you still need help or if you were able to resolve the issue on your own? If you need any further assistance, feel free to update us. If you’ve found a solution, sharing it with the community would be great so others with similar questions can benefit from your experience.
Best,
Rosie | Community Manager
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot.
Rosie
Message 3 of 8
dsouzasujay
Hi @mariuszhetman
Could you please follow below article and share the diagnostic log files?
If Fusion is not launching
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 4 of 8
mariuszhetman
No, there's no solution. I'm hearing from other sources that Fusion needs a newer system than I have. It's ridiculous that the program installs on the wrong system without informing me that it needs a newer one. I don't think there's a way to revert to a previous version of the program. What is this? 😳
Message 5 of 8
dsouzasujay
Hi @mariuszhetman
When reviewing similar customer cases, we’ve observed that Fusion supports macOS Sonoma 14 and above. Based on this, I’ve suggested that the customer upgrade their macOS version.
Could you please update to the latest macOS version and check if the issue is resolved?
System requirements for Autodesk Fusion
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 6 of 8
mariuszhetman
No, my computer is too old for this system; the latest it can run is 12.7.6 Monterey. Fusion worked fine before the last update. Right now, it's a stalemate—it seems impossible to revert to the previous version of Fusion, and working with the new one can be tedious...
Message 7 of 8
mariuszhetman
I'll add that the computer is old, but it's a pretty efficient quad-core unit with an i7 2.8GHz processor. Due to its good performance, I don't need anything newer for now 🙂
Message 8 of 8
DaveCoulton
  1. My fusion is unusable since the latest Update. I keep getting the window stating unable to load add ins. I no longer have manufacture on the drop down either. Also on a mac
