Problems after Loft
Problems after Loft
csimmons5
Problems after Loft
csimmons5
I haven't used the Loft function in a while. Today, though, it worked as it always has, without any errors or warnings. However, the comment box above the history goes black, and I lose the home and perspective selection cube in the upper right corner. The only way to get it back is to close the program and restart it.
Is anyone else having this problem? Fusion is up to date and running on Apple M2 Max Sequoia 15.2
Attached is a screenshot for reference.
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post.
günther
Warmingup1953
First up Save your work. You should start by Naming your project before doing anything at all (Good habit I try to stay doing!). Close and re-open
csimmons5
I have yet to find an answer and have tried it in several different designs. Using the Loft function always results in the same outcome: the cube at the top disappears, and the comment box at the bottom goes black.
csimmons5
I save my work, but not typically after every change or addition.  I probably rely on the autosave too much, lol.  The screenshot I posted was to show the error. It was not worth saving since it was nothing.  I do appreciate you taking the time to respond.
csimmons5
Thank you for taking the time to respond and offering to look at the file.  I feel like that is irrelevant since it is now happening in every single design; I just had it happen on a brand new design, and all I had done was a sketch, an offset plane, and a sketch. It happened when I pressed loft and selected the first profile.
TrippyLighting
Data is needed to find the root cause.
If you can create a screen recording of the behavior (I can recommend OBS studio)  that would help. Also, post the diagnostic logs right after this happens.
You can find those clicking on the question mark in the upper right corner -> Support and Diagnostics -> Diagnostic logs.
