Problem with tool path that may be a bug in latest version
tomae
tomae
I have a part that I generated several tool paths for a week or so back that work great.  I have a nearly identical part, slightly different dimensions, that I am trying to generate identical tool paths for.  I am literally copying the setup and tool paths from the working part to the model.  But two (of the 3) tool paths are not being generated correctly.
I would like to send the two models, I just don't want to post them in the forum.  Is there someone specific I can send them to or to a general support address?
-Tom
HughesTooling
What ops are failing? There was some problems with turning ops in the last update, does your original design still regenerate if you edit an op?
Mark
Mark Hughes
Owner, Hughes Tooling
tomae
Mark
A 2D Adaptive and a 2D Contour both have issues.  The original design has the correct toolpath.  But now that you ask...if I unselect things and try to regenerate it fails in the same way as the newer one.
On the 2D Adaptive the toolpath is appearing under a curve I selected rather than above the curve (for no apparent reason) and on the 2D contour one side of the tool path appears to be truncated.
These are both in a mill-turn part.
-Tom
HughesTooling
@seth.madore  Are you able to help with this?
Mark
Mark Hughes
seth.madore
Mark, thanks for tagging me!
@tomae email me the file if you'd like.
seth dot madore at autodesk dot com
Seth Madore
tomae
Thanks, I just sent the two designs.
-Tom
