Problem with the drawing module
m_tarczewskiCQUYB
Message 1 of 8
m_tarczewskiCQUYB
I'm having trouble creating a technical drawing in Fusion.  When I want to transfer the model to the drafting module, the program hangs and a white screen is visible in the program.  Anyone have the same problem?  Previously, I had no problem creating a drawing, but I also worked on another computer.  Now my computer has a weaker Intel i5, 13th generation processor and nvidia gforce 3060. Could this be a problem?
Replies (7)
Message 2 of 8
TheCADWhisperer
@m_tarczewskiCQUYB
Do you see the same behavior if you create a new file of a simple cube?
Message 3 of 8
m_tarczewskiCQUYB
With the simplest cube, the program still hangs. I can't do anything, not even switch to the modeling module. I have to disable the entire program.
Message 4 of 8
jhackney1972
Sounds like a Graphic Card issue.  Make sure you have updated your graphic drivers even if you are using "on-board" graphics.  After this try and chose a different Fusion 360 Graphic Driver in the Preferences.
John Hackney, Retired
Message 5 of 8
m_tarczewskiCQUYB
I updated the graphics driver. I selected a different graphics driver in the preferences. I restarted the program and unfortunately the problem still persists.
Zrzut ekranu 2023-12-19 213728.pngZrzut ekranu 2023-12-19 213746.pngZrzut ekranu 2023-12-19 213800.png
Message 6 of 8
jhackney1972
After updating your graphics driver, did you restart your computer?  Also, you said you changed the Fusion 360 Graphic Driver, did you try all three?  If this does not work and you are using a Windows based operating system, use the "Run" command prompt and enter "dxdiag" export the results and post them here.
If you are using a MAC, then you will have to wait for someone else to try and help.
Message 7 of 8
m_tarczewskiCQUYB
Yes, I reset my computer after updating the graphics card. I ran all three graphics drivers, resetting the computer and program with each change. I am sending the computer diagnosis in the attachment.
I don't know what to do here, I really need help.
Message 8 of 8
m_tarczewskiCQUYB
I finally made it! It turned out that a newer version of the C++ library had to be installed.
I found a detailed description of how to do it under this post:
https://forums.autodesk.com/t5/fusion-360-support/drawing-module-freezing-unresponsive/m-p/12044834?...
