Message 1 of 8
I came across a problem when mirroring a feature that had a "Distance & Angle" Chamfer. I set my chamfer to 60 degrees on a feature. When I mirrored the extruded feature and chamfer, the 60 degree chamfer did something that was not expected. The angle seemed to have changed position. This can be seen in the attached screencast. There is no audio as I do not have a microphone.
I have repeated the exercise using a 30 degree angle and the same shift occurs in the mirror.
Is this something that I am doing or is this a problem with Fusion 360?
