problem with extruding
hi in the below file as you can see there is a letter z and the z has been offset twice and i want to be able to extrude in-between the offsets but it will not let me do that can i please have help on this please i can extrude the others like the b and the o but cant with the z so please help me.
HughesTooling
The Zs are open, not closed profiles. Also you will find it easier if you only sketch one corner, extrude then pattern the extrusion rather than have six copies in the sketch. A lot less work to pattern the extrusion.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
The trouble starts in your first sketch of the Z. You either need to add a line between the open ends or make the circle the same size as the distance between the end points.
Mark Hughes
Hi thanks for that solution it is working but now i have another problem i need to be able to extrude the o without loosing the holes i have made is that possible or...
Hi thanks for that solution it is working but now i have another problem i need to be able to extrude the o without loosing the holes i have made is that possible or... file is below
