problem using huion tablet with fusion 360.
I bought a huion tablet for 3D designing.
But i am facing problem using huion wh1409 with fusion 360.
Wheneven i put dimensions it does let me enter more than 1 digit in dimension box.
The digits in dimensions box are always selected i.e., if i want to enter 15 dimension  , it will enter 1 but that 1 will be always selected(ctrl + a command) , and when i try to enter 5 after 1 to make it 15, it deletes the previous 1 and enter just 5.
It is very annoying.
Is there a solution or huion tablets just doesn't work with fusion 360 ?
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Thank you for posting and welcome to the community!
Sorry to hear that!  Which OS is Fusion running on?  Unfortunately at this moment I am not sure if Fusion supports Huion tablets - I will check this internally.  Thank you for your patience.
In the meantime, can you try doing a limit effect to optimize performance in the system and see if this makes any differences?
Also, have you tried doing an automatic clean-uninstalling of Fusion and re-install using the fresh installer from this web page?
Hopefully this helps!  If you have any questions, please let me know.
Thanks.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
leaonardo
is it still unsupported  ?
does the huion hs64 already work with fusion 360 ?
and with sketch up , eagle , tinkercad , autocad , revit ?
