PROBLEM INSTALLING FUSION 360
avinash
Message 1 of 8
avinash
I HAD PROBLEM DURING OPEN FUSION 360 (error:0X00000002).
SO I UNINSTALLED FUSION 360. AND TRIED TO REINSTALL IT.
NOW FACING PROBLEM IN INSTALLING- CorruptError: Database disk image is malformed.
Attached error screenshot and error log.
PLEASE HELP.
Replies (7)
Message 2 of 8
dooyoul_chung
Hello @avinash
Could you please try again to install after perform clean-up steps ?
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Dooyoul.
Message 3 of 8
avinash
THANKS dooyoul.chung FOR REPLY.
MANUAL CLEANUP DONE.
BUT ISSUE NOT SOLVED. FACING SAME PROBLEM.
CorruptError: database disk image is malformed.
Message 4 of 8
BaochengWu
Hi @avinash ,
Looks like the install data set corrupted. Can you try reinstall after removing all files under c:\users\admin\appdata\local\autodesk\webdeploy\?
Baocheng Wu
SW Engineering Manager
Message 5 of 8
Stuart-H
or the HDD/SSD has crashed
Mac Studio M1Max and MacBook Pro M1
Message 6 of 8
sutherland-
Might be the issue, since while installing the software, if the SSD/HDD disappears for a second, this issue will pop-up.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 7 of 8
avinash
THANKS ALL FOR YOUR TIME AND REPLIES.
PROBLEM SOLVED BY REMOVING ALL FILES UNDER c:\users\admin\appdata\local\autodesk\webdeploy\
AND REINSTALLING FUSION360.
KEEP SUPPORTING.
Message 8 of 8
Matskuuz
Community Visitor
Community Visitor
Thanks that worked👍
