When I want to create a new sheet metal component in a design I can do everything as normal including selecting an appropriate sheet metal rule. when I 'flange' the first simple sketch the browser shows the sheet metal rule and shows a new body has been created as a sheet metal part. However, the body is not visible!
Everything in the browser looks normal and highlighting the body in the browser and selecting 'find in window' zooms in on the sketch. when the sketch is hidden there is nothing there!
I can follow the exact same procedure in a new design without problems but also discovered that I can't create a second sheet metal body using a different rule. whatever rule I select for the second body, the part reverts to using the rule for the first body.
