problem at startup
problem at startup
anton.beck
Observer Observer
problem at startup
anton.beck
Observer
Observer
I have a problem regarding starting the application. After the small loading screen opens the application window but only with a white screen:Screenshot 2022-08-26 122521.png I already used qualtric survey solutions, including reinstalling fusion 360 and even the support couldn't help me.
I appreciate any help
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @anton.beck, thanks for posting.
If you contacted support, I suppose that you might have checked the related article but just for double-checking - did you try the following solutions: Black screen upon launching Fusion 360?
Another possible workaround could be connecting to the internet using the Mobile hotspot and starting Fusion 360. Once launched, switch back to the original network.
If the suggestions will not help, it may be worth trying a full clean installation of Fusion 360.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
