Print Drawings Failure
JcaveJRL8C
Observer Observer
JcaveJRL8C
Observer
Observer
Have printed a few drawings over the past couple days, until today Drawings will not print.  Only difference between this and the others was added pictures into the new one that will not print.  Verified printer is functioning by pasting screenshot of Fusion Drawing into Word and successfully printed but resolution is poor.
FATAL ERROR: Unhandled c0000094h Exception at A90CE18Ah
759433463
-KyleWilliams-
Hey @JcaveJRL8C
I'm looking into this for you. Have you found a solution yet?
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
liang_chen
Hi @JcaveJRL8C ,
I test the drawing files with image, specific for high resolution image, but do not meet the crash when print drawing
Can you pls share the dataset for testing? And it will be highly appreciated that you can share a video about how to run into the crash. Maybe some settings cause the issue.  Thanks
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
liang_chen
It has been reported as internal ticket (FDWG-18595) for investigation. If there are dataset and steps to reproduce it, it will be helpful for issue investigation. Thanks
Fred Chen
SQA Engineer
Autodesk, Inc.
JcaveJRL8C
Observer
Observer
I have not.  It did not happen with another file.  And then it just happened again on a different file.  Other posts asked for datasets.  I'm not sure what file to send or to where to help with the investigation.
liang_chen
If it happens on specific file, please navigate to the drawing file which is failed to be printed in Data Panel; right hit the file and share it; then share the link with us. Thanks
Fred Chen
SQA Engineer
Autodesk, Inc.
