Precision errors measuring Construction Features
mavigogun
Advisor Advisor
mavigogun
Applying the measurement tool to confirm the disposition of Construction Planes is producing inconsistent results.   In the accompanying screencast, each measurement of the angle between two Construction Planes generates fractionally variable reports.   This introduces a degree of uncertainty- is there really an error in the geometry of the feature?   If so- even at such a small scale -the amplitude will increase to significant proportions as dependent Construction features form the basis for subsequent Constructions.
Thoughts?
paul.clauss
Hi @mavigogun
Thanks for posting! We appreciate the detailed screencast and verbal description of the problem.
This issue is stems from the current ASM tolerance in Fusion 360 - the ASM kernel in Fusion 360 has a tolerance of 1.0e-6. All computations have some noise to them at some level and it is expected that Fusion 360 will show some slight inaccuracies at a precision higher than six decimal points. Unfortunately, there is no workaround for this behavior - the tolerance should be small enough that it should not effect the design or most manufacturing processes down the road.
This issue has also been discussed on this thread, in which it occurred when measuring the depth of a hole.
Hopefully this helps! Please let me know if you have any questions - I am happy to help.
Paul Clauss
Product Support Specialist
HughesTooling
I just tried the same exercise and I don't get any rounding errors! Tried all axis and planes all return 72° with all decimals selected in the dialog.
Edit after a bit more digging I found you need to set the accuracy for angles in preferences to 9 places. Seems odd that the precision in the measure dialog is overridden by the accuracy in preferences. What I mean is while working and entering dimension 3 or 4 decimal places is fine but if I want to measure to all decimal places with the measure dialog that's what I should see.
Mark
Mark Hughes
Owner, Hughes Tooling
