Precision error in empty sketch space.
rpaldi2
Message 1 of 9
rpaldi2
Just in empty sketch. I think it cause sketch precision error... Can it be updated?
Replies (8)
Message 2 of 9
TheCADWhisperer
@rpaldi2
I didn’t see you type in any dimensions?
Message 3 of 9
rpaldi2
No it's just an empty space I've opened just before
Message 4 of 9
TheCADWhisperer
It’s not empty space - I see you create under defined geometry in the space?
Once you create geometry (under defined or fully defined) the space is no longer empty.
Can’t you see the geometry you created? What graphics card/driver are you using?
Message 5 of 9
g-andresen
check your preferences
günther
Message 6 of 9
rpaldi2
I've already checked, but it's just invisible. When measured, the error still exists
Message 7 of 9
rpaldi2
How do i define my geometry?
After Restart computer - launch Fusion, That still happens.
RTX2060 442.80
Message 8 of 9
HughesTooling
Well I was quite suppressed to find even if I fully constrain the sketch before offsetting you do still get that small error (too small to measure in the real world). But if you just type 1 in as the offset it is accurate.
After typing 1 then editing the dimension. My advice to you would be turn off the grid, turn off snap to grid and then full constrain and dimension your sketches. If you enter a size in a dimension it will be accurate.HughesTooling_1-1689237500958.png
Mark Hughes
Owner, Hughes Tooling
Message 9 of 9
TheCADWhisperer
@rpaldi2
Attach file here as originally requested for demonstration.
As stated previously - I did not see you typing any dimensions.
