Precise Modify
Precise Modify
Message 1 of 8
Precise Modify
Good day,
I do not understand how can i Precisely modify faces or edges by extruding or doing other actions. For example, when i do Press Hull, i can modify distance only by 10mm, however i want it to be precious as 0.0001mm, 0.0002mm,  0.0003mm and etc.
You can find attached file, that shows you increasing value only by 10.00 mm.
Also when i do fillet it changes value by 5.00 mm. I want it changes for MORE PRECISE VALUE!
I have start up license by the way.
Thank you in advance!!
Replies (7)
Message 2 of 8
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous ,
The drag tool is based adaptively on how zoomed in you are (i.e. that is why it is going by 10mm increments). If you want a precise number you can manually type the number in the dialog:
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 3 of 8
I have seen how people can modify it very precise, so if you say that the zoom is problem, how can i change it?
Message 4 of 8
I need this value could be changed with arrows automatically, i have seen many people can modify it with an arrows, they did not typed it manually
Message 5 of 8
I have changed zoom, it does not work, now it changes by 1000 mm.
Screenshot is attached
Message 6 of 8
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous ,
Then you need to zoom way way in. If you zoom in closer to the actual face that you are extruding (you will have to be super close for .001 moves) - you will notice the value changes when dragging.
James Youmatz
Message 7 of 8
HughesTooling
Is incremental move unchecked? Also are the other snaps unchecked?
Mark
Mark Hughes
Owner, Hughes Tooling
Message 8 of 8
Thank you Very much it helped me SO MUCH!!
