Post Processor that outputs in .lxds format
ayan_ali9212
ayan_ali9212
Haloo guys,
Hope you are enjoying this festive season.
We recently bought an ACCURL Laser cutting machine: Model is Pearl-1530 (at least according to the branding on the side). We are using the HypCut laser cutting control system. So far we have been inputting DXF files to do our machining.
I would like advise on which post processor can we use to run it that is compatible with Fusion 360.
Currently it translates any DXF file into .lxds format and I have attached the simple DXF file and the output from the HypCut software which was a .lxds file but I converted it to a text file.
We also have an old Plasma cutter that accepts G-codes from FastCAM. I was also hoping if you could suggest a post processor that produces a similar output to the attached FastCAM file (text file) of the same DXF.
I used the Jet Template (Demo Only) post processor in the Fusion 360 library but it still requires a machinist to input codes for things like "Turn on cutting here". I am not a machinist unfortunately. I will also attached the file.
Please help.
Grateful to be part of this community
ayan_ali9212
Here is the output from the Fusion 360 Jet post processor.
I look forward to your feedbacks.
