Post Processor for Cam
tanger1945
tanger1945
Hey All.
 I am trying to get an old machine tool working, What I have is a retrofit Supermax YCM40 3 axis milling machine with an Anilam Crusader M control. I can use the post to do most things but when I get to anything circular the post will not include the x,y,i,j, on the same line, sometimes it will drop the x and sometimes it will drop the y. The machine needs to have it all so it will not error out (circular error). I am just learning how to edit post processors now but for the life of me I cannot understand why it drops either the x or y coordinate.
rushikesh_nagalkar
Hii there
could you provide more details so we can better understand the issue?
please share the project file and the post processor you're using for it.
tanger1945
I have attached the Post that I am using and the Fusion project I was working on. Let me know if you have any questions. Thanks for looking at this. I will try to get pictures of what the machine screen has on it.
rushikesh_nagalkar
Hi there,
It appears that significant changes have been made to the post processor, and it is also an older version. Additionally, the IJK values are different, assuming they work with your controller.
If x,y,z.. has the same value as the previous value, in a next call it will not write those value.
Here are some of the ways to force the values
If you want to specifically force X and Y for G02 and G03 moves,
use
xOutput.reset();
yOutput.reset();
The below image: Force X Y values only for circular path in XY plane.
tanger1945
Thank you, I think that did it, i will load on machine to test it.
tanger1945
I was able to load and run programs into my machine and they are now working. I have attached working post for Anilam Crusader M .
