POST PROCESSOR ERROR. Parameter does not exist
martynas.rKKLK9
martynas.rKKLK9
Hello
When ever i am using circular strategy, my post processor gives me an error.
Anyone has any ideas what kind a issue im having?
Information: Configuration: Mazak
Information: Vendor: Mazak
Information: Posting intermediate data to 'C:\Users\martynas.r\Desktop\1001.eia'
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Wednesday, September 8, 2021 5:48:44 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.5793.0
Configuration path: C:/Users/martynas.r/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/MAZAK.cps
Security level: 1000
Include paths: C:/Users/martynas.r/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Tuesday, August 24, 2021 1:27:13 PM
Output path: C:\Users\martynas.r\Desktop\1001.eia
Checksum of intermediate NC data: 9f87c47654d24d7312a56f781cb5c810
Checksum of configuration: eebda69a0a176a612003b27b8cdf69e2
Vendor url: http://www.autodesk.com
Legal: Copyright (C) 2012-2021 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.10813
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Error: Parameter does not exist.
Error at line: 1
Error in operation: 'Circular1'
Stack dump:
("Parameter does not exist.")@:0
initializeSmoothing()@C:/Users/martynas.r/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/MAZAK.cps:662
onSection()@C:/Users/martynas.r/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/MAZAK.cps:1036
Failed while processing onSection() for record 7747.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, September 8, 2021 5:48:44 AM
Post processing failed.
seth.madore
Huh, odd. Can you share the Fusion file and the post processor here?
Seth Madore
martynas.rKKLK9
Both of the ppost gives me the same result, btw it has a lot of modifications, maybe thats the problem?
