Post Process dialog doesn't remember previous selection
SGoldthwaite
Message 1 of 8
SGoldthwaite
Every time I use the post processor, the dialog opens but defaults to settings I don't want.  Why wouldn't it default to the last thing I used? Every time I have to click the Setup button to tell it where to get my posts, it's always defaulting to c:/users/scott/appdata...    Then I have to set the Output Folder again.
Replies (7)
Message 2 of 8
marcus.greenwood
Hey Scott,
I am trying to reproduce this problem but can not. Are you posting then immediately opening the dialog back up? If not, what are you doing in between dialog openings?
Hopefully, we can sort this problem.
Marcus Greenwood
Software Engineer
Message 3 of 8
g-andresen
Maybe you'll find a better auditorium in the Manufacture Forum.
günther
Message 4 of 8
SGoldthwaite
When I post, then go right back and try and post again, my previous selections are not saved.  See screencast.
Message 5 of 8
rhdfmail
This is still an issue that seems to affect some users, like me.
I started a thread about it but the main issue then was that the post lost all machineconfig settings (like home positions)
Now it just seems to ignore the post-settings in machine-config and keeps reseting to the local folder and the default outputfolder
Message 6 of 8
marcus.greenwood
Hello, unfortunately, I am still unable to replicate the problem which makes me believe it is a specific MFC registry problem with windows. We have also made note of several other problems with the dialog that is of a similar nature. I am hoping these problems will be fixed when we upgrade the dialog to be QT based instead of MFC, which we are currently working on. I'm sorry I can't offer an immediate solution though.
Marcus Greenwood
Software Engineer
Message 7 of 8
same problem here..
Message 8 of 8
rhdfmail
The problem still exists, but it works as intended  for one job and for another i have to select the post-processor everytime I post.
When the correct one is selected all settings for outputfolder etc is correct, so the info for outputfolder for that postprocessor is stored somewhere
