Position of component within sketch changes in Edit Sketch mode
dieter.menne
dieter.menne
The component "Batterie" is aligned in the top corner of the case sketch. When I switch to "Edit (case) sketch", the position is shifted.
g-andresen
please share your file.
File > export > save as f3d local > attach to next post
günther
dieter.menne
This is a slight variation to the above which I tried after reading some postings, where the case sketch is at the root level, but the effect is the same. I wouild not mind the shift because 3D is correct, but I fail to get a project of the holes onto the case sketch correctly.
dieter.menne
After I downloaded the version attached above, I reloaded it into Fusion, and everything works as expected now.
Looks like some inconsistent data in the version that is cleaned up on saving.
