Please persist parameters window
JetForMe
JetForMe
It would make using parameters much easier if the window could be opened and left in place. When in sketch, I can open the window and it appears as a floating utility window (macOS). I can move that off to my second monitor, and go back and forth between it and my sketch. But the minute I finish the sketch, the window closes. Next time it opens, it opens in its default location, not where I had it.
I would be a lot more useful if it just stayed where I put it, and always stayed open. In fact, it should open back up to where I left it the next time I launch Fusion.
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
lance.carocci
Thanks @JetForMe, I will pass along this feedback.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
