please help i dont know whats wrong
How did it go from such a detailed model (before i pressed finish form) to such a crappy quality model (after i pressed finish form).
note: im quite new so dont judge me i guess.
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to the community!
Thanks for posting.  I imagine it might be necessary to display a model more detail.
So can you please try to change the display level in the Display Detail Control window (as below) and see if this makes any differences?displaydetailed.png
If this does not help, would you mind posting a public link to the model in this thread so I can take a closer look at this?
Thank you.
Kanehiko SAITO
Product Support Specialist
Fusion Webinars | Tips and Best Practices | Troubleshooting
Thanks for your answer kanehiko!
unfortunately, your solution did not work, although, after a restart to my computer and a reinstallation of fusion360, this problem was fixed.
Victor Raduca.
ok, now i have a bigger problem, i clicked finish form, and the mesh turned out good, until fusion360 decides to crash on me, 😞
would you know any way to make sure it doesnt crash.
ps: i cant upload the file because its unable to save when i do finish form as the crash is instant.
saito.kh
Autodesk Support
Autodesk Support
Hi @Anonymous,
Thank you for the update.
I am sorry to hear that.  Just to check - can you please turn on "Limit effects to optimize performance" in the Graphic Diagnostic window - see this web page for detail, and see if this makes any differences?  At this point I imagine it might be related to the graphic card in the system.
In the Graphic Diagnostic window, you would also please check if Fusion is using the graphic card and the up-to date driver correctly in the system. - can you please share the screenshot of the window with me?
As I searched reports from you with the email address associated with this posting, I did not find them at this time - would you mind submitting the report if Fusion crashed for the next time?  - it will be helpful to investigate this behavior!
Hope one of these helps.
Thank you.
Kanehiko SAITO
