Planes
Planes
Planes
Can someone help?
on the AutoDesk website it shows planes on start up as below
however when I start the program I see the planes as below
which is correct?
wmhazzard
Both are correct, it just depends on you preference of whether you want the Y axis up or the Z axis up. You can change the orientation in preferences.
jhackney1972
In addition to @wmhazzard, I think you have touched the view cube accidentally.  If you see this orientation, try and touch the indicated icon beside the view cube in the upper right hand corner of the design area and see what happens.
John Hackney, Retired
TheCADWhisperer
Technically those images are the same.
Red=X
Green=Y
Blue=Z
You can change the orientation of what you call Top, but X is still X, Y is still Y and Z is still Z.
This gives you a universal coordinate system between various CAD softwares.
thanks for the explanation(s), I have managed to change the view via preferences
