Plane Selection
Plane Selection
russellmcaliece
Plane Selection
russellmcaliece
When I select sketch mode and the plane I want to use, fusion does not automatically align to the selected plane. Why is this happening? It did not use to be like this.
jhackney1972
There are two reasons for this.  The most likely one is that you are sketching in 3D mode.  Start a sketch and check your Sketch Palette and see if you have 3D sketch checked.  If so, uncheck it then Finish Sketch and start a new one to see the result.
The other possible reason is you have turn off Auto Look At Sketch in your Preferences.
John Hackney, Retired
