Performance deteriorates with the window size of Fusion
waldemar_noll
Observer Observer
waldemar_noll
Observer
Observer
I noticed that on the M4 mac mini (16GB RAM) with a 1440p Monitor, the amount of lag and stutters increases proportionally to the size of the window, when you view/move around models (you can see it in the video). Is my Hardware not good enough, is it a potential bug or is there a simple fix for this?
lance.carocci
That is expected. The canvas viewport is not a fixed resolution, and scales dynamically with the application window size. As a result, performance tends to degrade as the canvas gets larger relative to the rest of the UI.
AA and AO are most-taxing on graphics, so turning those off will make the biggest improvement on framerate. I recommend utilizing the dynamic detail setting within Preferences > Graphics - setting the minimum navigation framerate to 60 should automatically toggle these off during canvas movement, and back on once the model is stationary.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
waldemar_noll
Observer
Observer
This helped massively thanks, butter-smooth now.
